Braided lines are about 2 years old, don't remember brand, but probably Summit generic braided lines...
Car sat the whole time with E85 in the tank, started about every month to keep the battery charged.
https://goo.gl/photos/HxLz7ksXMY1hNYjz5
E85 @ Summit fuel lines.....
Noisy Cricket
Re: E85 @ Summit fuel lines.....
Images not loading, but...
Never, ever, EVER store E85 in an unsealed container like that. If you're going to lay up an E85-running car for more than a month or so, pump it all out and refill the tank with gasoline and run it a bit to flush the lines/injectors out. That way it won't absorb moisture from the air and turn corrosive.
It's not nearly as bad as methanol but you still need to be cautious. This is why IMO any E85 car really should be done as a flex fuel setup. (Well, that and E85 isn't always 85% ethanol)
Pete, that rallycross guy
'06 Volvo S60 R (Swedish GTR)
Yeah, summit racing nitrile hoses are not merely enough protection against deterioration.type85 wrote:Braided lines are about 2 years old, don't remember brand, but probably Summit generic braided lines...
Swap out all fuel related hoses with PTFE conductive hose.
http://www.theprojectpad.com/viewtopic. ... tfe#p53577
mushasho wrote:Yeah, summit racing nitrile hoses are not merely enough protection against deterioration.type85 wrote:Braided lines are about 2 years old, don't remember brand, but probably Summit generic braided lines...
You have a specific brand you can suggest?
Noisy Cricket wrote:Images not loading, but...
Yiikes!!
Yeah, learned my lesson!
I've purchased from these 2 places.type85 wrote:You have a specific brand you can suggest?mushasho wrote:Yeah, summit racing nitrile hoses are not merely enough protection against deterioration.type85 wrote:Braided lines are about 2 years old, don't remember brand, but probably Summit generic braided lines...
You can speak to Stuart directly Techna-Fit
https://www.technafitstore.com/category-s/1865.htm
http://anfittingsdirect.com/
Thanks for the links, Ob... fueling lines, fittings and intercooler piping is next on my punch list. Prices look good, now I just need to find a local supplier for comparison's sake.
