1990 Audi 90 quattro AAN
Posted: Thu Oct 13, 2016 2:56 pm
by Pnw90^2aan
I'm Chris from Bellingham, WA.
Acquired my 90 May 2014 with plenty of maintainence and proper upgrades.
Currently she sits at 290,576 miles on the odometer.
Photo documentation: https://goo.gl/photos/3jeoLtWV1QqM91Fi6
Over the 2 year course;
Assembled AAN:
Balanced bottom end
H-beam Integrated Engineering connecting rods
new main and rod bearings
MLS headgasket
ARP main studs
Goetze piston rings
All new, OEM seals. Yes, all of them.
Majority of engine fasteners replaced w/ new matching fasteners
All hose clamps replaced w/ marine grade SS
timing belt kit
hardened crankshaft gear plus crank bolt
7a Intake and exhaust camshafts
Adjustable billet cam gear
OEM lightweight lifters for engine break in and learning to tune w/ vems and k24 (will return to solid lifters with later turbo/mani upgrades)
New Intake/Exhaust valves, guides and seals with valve seats cut 3 angle
Rs2 exhaust manifold
550 CC injectors
H.P motor mounts
7a valve cover
7a singlemass flywheel
On the car;
034 Track density line: swaybar/links, strut mounts, differential mounts
poly: subframe bushings, diff mount, control arm bushings, snub
lower ball joints
wheel bearings
rear diff seals replaced
8 new CV boots
b3 20v rack & pinion
audi 4000 rear sway bar
bosch 044 fuel pump
EFI ls2 coil pack conversion
VDO oem matching boost gauge in vent
01E 5 speed transmission
Porsche Boxter 4 pot calipers
Daily drove her for a little over a year including a trip to SLC where I rode in Ben L's s2 coupe, did a mountain cruise with Dave picaro with one of his b4 1.8t, and another 90, can't remember details. After that summer I knew I needed to turbo charge my car.
Dec 2014 I found a 1995 URs6 avant from Colorado with some proper mods and a solid running car, except it was not pretty. Broken headlights, bumpers, faded, rock chipped and rusty, looked as if it had seen some salty snow mounts. Car arrived Christmas Eve, drove it till New Years and on a car club cruise during the 1 day of whatcoms snow Jan 4th, a subaru came around a corner too fast and totaled the drivers side fender, wheel, and inter cooler. Insurance payed for it all :hail:
I know a lot of you have helped me through input and knowledge through other groups/pages but I wanted a place to start documenting my build only on PP. Here is my main photos page for anything I will post.
Have a great weekend!
Christopher
Re: 1990 Audi 90 quattro AAN
Posted: Thu Oct 13, 2016 4:11 pm
by alxdgr8
Are you friends with Pat and the guy that bought the interior from Vlad? Welcome!
Posted: Thu Oct 13, 2016 6:02 pm
by Pnw90^2aan
I have yet to meet pat. I've seen some of his 5 cyl parts at the local powder coaters with his name on it. My dad has spoken with him but I'll get in touch with him now that I have access now
Posted: Mon Oct 17, 2016 4:27 pm
by Afterthought
alxdgr8 wrote:Are you friends with Pat and the guy that bought the interior from Vlad? Welcome!
The guy that bought the interior from Vlad is my buddy JJ but I don't think he has an account here yet, he's got a lago Blue 80 Quattro and a 200 20V Avant. He has the interior in but needs me to weld some serts in to bolt the seats down.
Between the three of us we are going to be bringing up the old school audi content in the area by a large percentage, Ha.
There is another guy that has a 3B swapped coupe in town I believe also named Chris .
Chris Welcome to the forum. How far into the project are you?
Posted: Wed Nov 09, 2016 10:59 pm
by Pnw90^2aan
Is JJ from Bellingham? I see an 80 quattro by work all the time, always parked, never on the street but it moves around. Ive seen everyone but Pat I think, lots of UR-S cars i feel like.
I almost have my AAN in longblock form. Gotta tighten my ii rods, not sure how, ive heard different directions of doing it. Then 7a oil pan, rear main flywheel+clutch. few hoses here and there. Using VEMS with the 7a to aan adapter. Gotta get that wired in.. Hard to get worktime in the daylight, living out in sudden valley. When it rains it pours too.
OKAY heres my first pics, I think I'll do everything via drive because im syncing 3 different devices to have all the tied photos. How do I upload pics to show IN the thread?
https://drive.google.com/file/d/1Mn0twJ ... sp=sharing
https://drive.google.com/file/d/1lnT_CQ ... sp=sharing
Thanks for the welcome! Hope i can stay somewhat active around these parts
Posted: Sun Nov 13, 2016 2:07 am
by Pnw90^2aan
Good evening, got a nice cruise in tonight up 542 E to 9 S, then lake whatcom on home!
Okay, heres first of many questions to come.
Im using a b3 vacuum break booster to get rid my oh so leaky bomb.
I have a 20v p/s pump, Im using the aan p/s pulley to remain serpentine setup
which bracketry do i use to make it work on aan block?
I have each mount for all p/s types for our cars
7a mountImage
aan mountImage
20v mountImage
EFI Express has a 20v bracket conversion
http://www.efiexpress.com/catalog/produ ... cts_id=132
Wondering if that is what I'll need to make it work.
Whats the proper way to torque the integrated engineering rod studs?
im using 7a oil pan for clearance, should I keep the aan windage tray or go with 7a?
which order does the oil pan gasket go between the windage tray and block?
p.s I sure hope I figured out the image thingy :bangshead:
Posted: Thu Nov 17, 2016 9:55 am
by Afterthought
Pnw90^2aan wrote:Is JJ from Bellingham? I see an 80 quattro by work all the time, always parked, never on the street but it moves around. Ive seen everyone but Pat I think, lots of UR-S cars i feel like.
JJ has a lago blue 80 Quattro that he drives right now but will be tearing apart soon. I live out in Ferndale now so I've lost touch on whos got what... never see any Audis out here! Tim has a really nice 1995 Pearl S6 Avant that is getting a fully built and tuned engine right now.
There are also quite a few friends I have that have really fast B5 S4s that are well above the "stage 3 " off the shelf K04 level. But they don't know what a real car is :)
Pnw90^2aan wrote: Im using a b3 vacuum break booster to get rid my oh so leaky bomb.
Let me see if I can jog my memory as I went through all this on my coupe.
I used almost all AAN stuff.
Remind me which intake manifold you plan to run?
If you run an AAN intake manifold, and AAN water pipe the bracket that Hank sells will not clear all those items.
I don't have any pics of my coupe that I can find right now but I ran the AAN setup, serp belt, tensioner, brackets, intake manifold, water pipe.
For the B3 booster I ran a stock Power steering rack, and B4 90 PS pump. but I would recommend finding a 4000 rack or similar if you can. Basically one that came from a car that runs vacuum boost because your stock rack has provisions for the bomb , extra lines.
Pnw90^2aan wrote: Whats the proper way to torque the integrated engineering rod studs?
I don't remember what I torqued my conn. rods to, but you want to double and triple check your bearing fitment , use oil or engine assembly lube, and continue rotating the engine by hand as you tighten them down to make sure nothing is tight and binding up.
Pnw90^2aan wrote: I'm using 7a oil pan for clearance, should I keep the aan windage tray or go with 7a?
I would recommend using the 7A pan, and transfer over the AAN windage tray. You want to use the pickup tube that goes with it's respective pan so stick with 7A pan, 7A pickup tube.
For the windage tray, you need two gaskets. If you look at the factory part numbers I believe there are two thicknesses of that gasket and I used two of the thinner, so you should have block -> gasket -> tray -> gasket -> pan.
Posted: Sun Nov 20, 2016 9:02 pm
by Pnw90^2aan
[/quote]
For the B3 booster I ran a stock Power steering rack, and B4 90 PS pump. but I would recommend finding a 4000 rack or similar if you can. Basically one that came from a car that runs vacuum boost because your stock rack has provisions for the bomb , extra lines. [/quote]
I also have a b3 20v parts car I could use the rack from then, no bomb which is where the booster was acquired.
[/quote]
For the windage tray, you need two gaskets. If you look at the factory part numbers I believe there are two thicknesses of that gasket and I used two of the thinner, so you should have block -> gasket -> tray -> gasket -> pan.[/quote]
Thank you, I did not realize there were 2 gaskets. Ill talk to parts dept. tomorrow for that second gasket.
Found the rod torque info here
http://www.performancebyie.com/blog/connecting-rod-faq
I think I'll be doing a lot over thanksgiving weekend on the 90.
Posted: Thu Feb 16, 2017 1:06 am
by Pnw90^2aan
Hello again!
I've made some good progress over the new year.
Heres a link for any pictures I will be adding. Hopefully I put the settings right
Rear subframe is being assembled, soon I will add wheels and roll it under the car after I install the new tie rod ends.
Only need to order tie rods and swaybar end links to complete rear subframe.
I've chosen all track density bushings/mounts , poly subframe bushings/control arm bushings.
Replaced wheel bearings, lower ball joints, all 8 CV boots
I broke the rear most differential mount, snapped off one corner of the bolt holes... already had junked the 89' quattro parts car, still need to sorce one of them. Any tips on removing the bushing from that mount?
Yesterday is was the 2 year mark I pulled the AAN from the 95' Ur-S6 Avant
Ive been messing with different p/s pump options and came to deciding the B4 pump in the AAN bracket, checking picknpull this weekend for b4 v6 p/s pump and a 4000 driveshaft hopefully for 50% off weekend.
The b3 20v steering rack is cleaned up with a new boot on, ready to be installed, with new steering end links.
I will do the same as the rear subframe to the front subframe when I am figuring out the installation of VEMS,
as well as replacing 2 doors, fenders, bonnet wind shield, and removing battery box, and rerouting the battery cables from the back. :drool:
Thats all for tonight. mostly just an update.
Posted: Thu Mar 30, 2017 11:53 am
by Pnw90^2aan
Slow progress.. I wish it'd stop raining!
On the rear subframe:
Installed my caliper brackets, brake shields and rotors.
One axle is in, didn't realize I forgot a C clip at the end of the inner CV joint.
I may be missing the sleeve spacer for the short C.A side swaybar linkage, FCPEURO has 10$ each.
I just need to fill differential w/ mance mix gear oil recipe and she can be INSTALLED!!
(PICS IN MY GOOGLE PHOTOS ALBUM)
The body:
Interior is stripped minus headliner. Cleaned the base floor, seat rails and everything else while its like this.
I replaced the passenger side doors, I need to install the new fenders and hood.
The drivetrain:
I need to swap 01e axle cups with b5 a4 rear cups for my 100mm stock axles for now.
Transmission is seals and cups from being installed, plus mance mix.
4000 driveshaft has new carrier bearing and awaits install
April 6th I get to pull my car into the garage finally, to install the trans and engine. Might get another post sometime in that week.
Posted: Fri Mar 31, 2017 10:36 am
by Silverswift85
Nice setup!
Posted: Tue May 02, 2017 11:23 am
by Pnw90^2aan
I regularly update my pictures on the album, not so much my thread.
01E transmission is in with Iroz rs2 replica mounts,
I am just waiting on my pilot bearing (which I thought would have come with clutch kit from 034...)
Steering rack, linkages are all in, refinished brake booster will be next, along with ABS lines and harness routing.
Engine is awaiting on the stand for rear main, torque oil pan bolts and start flywheel/clutch disc/PP assembly,
then transplant!
Interior bits are being collected for a total black interior. I may be going down to Toledo, WA
for carpet/insulation and various trim pieces I am missing from a parts car.
On my EFIX ls2 coil conversion VEMS PNP harness there is a fused power wire, I am wondering whats a common 15 power to put that in, maybe if somebody has a diagram for it that would be great!!
Another link to the album
