K26 Turbo, 1mm of side to side play only - $125
(2) MAF's - $40 each SOLD
3B injectors - $50
Oil pump - as you can see, it was damaged when screws that were too long were used on the crank pulley, pop the seal and file down and it should be good to go - $25
3B turbo coolant hose - $20
3B crank sensors - $75 SOLD
T44 radiator resistor pack - $15- SOLD
(1) 034 density line engine mount - $40
(2) ignition coils - $75 each
Drilled wastegate housing, I have the spring if you want as well - $25 - SOLD
Distributor cap - $10
Prosport 60mm EGT gauge - $75
Prosport 60mm electronic boost gauge - $50 SOLD
3B oil pan - $100
T44/RS2 Radiator fan - $100- SOLD
B3 90 steering wheel - $20
Pair of Red Urethane (motorsport) Rallyarmour mud flaps - $50
(2) Black Status 3" 6pt harnesses, 2014 expiration date - $100 each
Aeromotive FPR with fittings and gauge - $60- SOLD
Vraxx FPR with barbed fittings - $25
Odyssey PC680 battery - has 12V currently, I upgraded to a bigger battery for the rally car - $80 - SOLD
