Page 23 of 34
Posted: Thu Mar 06, 2008 2:28 pm
by derracuda
on the rear end i had the delrin bushings made up a long time ago, and those worked pretty well back there. the fronts you can't use delrin because of the two axis movement of the steering arm... but i do plan to use sphericals up front on this project 8)
Posted: Fri Mar 07, 2008 9:12 am
by Jretal
derracuda wrote:on the rear end i had the delrin bushings made up a long time ago, and those worked pretty well back there. the fronts you can't use delrin because of the two axis movement of the steering arm... but i do plan to use sphericals up front on this project 8)
you mean for the rear tie-rod? like the portion that attaches to the subframe?
Just making sure... I like where your heads at
Posted: Fri Mar 07, 2008 10:33 am
by derracuda
yes, at the inner rear tie rod mounting point. unfortunately, the stock 4kq rear tie rods are kind of dying out, so there wasn't much sense in making a run of 100 sets of delrin bushings :( so from here on out, it'll be spherical rod ends on this car.
Posted: Fri Mar 07, 2008 1:39 pm
by derracuda
mmm, brakes
312x25mm A8 rotor next to a 340x34mm monster rotor
takes up a lot of space behind a 19" rim... too bad i can't run 19's on this car, otherwise 11" wide here i'd be comin'!
i hope to have a 5x130 hub conversion update here in the next week or so depending on my machinist's schedule. i think you'll all approve very much.
Posted: Fri Mar 07, 2008 1:48 pm
by s2 on the way
niiiice....
I'm likin the twists better anyway even if the 19s did work out...
plus, don't you think 10 in is wide enough
Posted: Fri Mar 07, 2008 1:51 pm
by derracuda
if i was going to use the gallardo rims, i wouldn't need to convert to 5x130, but just 5x112 instead. and yeah, 10" is enough i guess *shrugs*
Posted: Mon Mar 10, 2008 8:36 am
by Jretal
derracuda wrote:yes, at the inner rear tie rod mounting point. unfortunately, the stock 4kq rear tie rods are kind of dying out, so there wasn't much sense in making a run of 100 sets of delrin bushings :( so from here on out, it'll be spherical rod ends on this car.
Ah, gotcha. Did you follow the same design concept as the CA bushings, or did you make two separate halves w/ shoulders instead?
Just curious as that'd be something I'd consider doing. But after buying new arms (~$80 each) and then paying for machining for the bushings ($??) you'd probably be close in price to the 034 ones at $200ish.
decisions decisions
HOpefully my rear tierod ends are OK for now, so won't have to cross that bridge yet.
Posted: Mon Mar 10, 2008 9:58 am
by derracuda
i did two piece bushings with a shoulder 8)
Posted: Wed Mar 26, 2008 7:01 pm
by mojackson2390
I AM IN LOVE WITH YOUR 4KQ!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted: Wed Mar 26, 2008 8:27 pm
by thegetawaycar
mojackson2390 wrote:I AM IN LOVE WITH YOUR 4KQ!!!!!!!!!!!!!!!!!!!!!!!!!!!!
lol! most of us around here are. You will find Derek does some damn fine work.
Posted: Tue Apr 01, 2008 11:58 am
by derracuda
viola' 5x130 using the existing 4x108 hubs...
what we have here are steel rings, machined to fit the stock hubs (also slightly machined for perfect fit) from the backside, sandwiched together as a package from the adapter, through the stock hub, through the rotor, and the wheel. it's all hub centric and there's nowhere for anything to go 8)
.002 interference fit.. fits like a glove
chevy truck 14x1.5mm wheel studs. the new bolt circle puts them out away from the spindle enough to replace with the hub still in the bearing.. in the spindle/bearing housing.
the rear hubs sit further in, so the adapter had to be machined a bit for clearing the sprindle/bearing housing.
test fit in the porsche wheel...perfect.
test fit in the 345x32mm rotor... perfect (just need to drill the holes myself)
Posted: Tue Apr 01, 2008 12:15 pm
by PxTx
Took me a minute to fully grasp what you did here, but nice work! I guess there is no need for welding with this setup. Can't wait to see how things progress. :-)
Posted: Tue Apr 01, 2008 1:41 pm
by Hybrid_Hatch
April Fools?
Don't think so... anyway when do Derracuda's one stop wheel adapters go on sale to the general public?
Posted: Tue Apr 01, 2008 2:11 pm
by derracuda
correct, no welding. after some discussion with the machinist, we determined that welding wouldn't be the best route since for the best outcome, we'd need to test the hub to get the metal identified, then find matching material, then for the welding, then for heat treating, and then for machining... this was the simplest, safest, most straight forward concept. thanks to maarten of NL for helping spawn the idea 8)
as for selling them... i'd have to see how it works out first. and i don't have a store or anything, but i could do a one by one basis conversion if someone asked me to. i'm not set up for production by any means.
Posted: Tue Apr 01, 2008 5:25 pm
by Wizard-of-OD
Derek why dont you cut a V-channel on the surface where the rotor sits and weld the 2 pieces together rather than press fit?Just for added security?
Posted: Tue Apr 01, 2008 5:35 pm
by cuatrokoop
He didn't want to weld because of things like heat treat, plus with the studs passing through the ring, it acts like a clamp. I don't see an issue with it.
Posted: Tue Apr 01, 2008 5:36 pm
by Wizard-of-OD
Better to over engineer than under engineer....
Posted: Tue Apr 01, 2008 5:45 pm
by derracuda
but welding and messing with the metalurgy is called de-engineering
it's fine the way it is man
Posted: Tue Apr 01, 2008 5:51 pm
by cuatrokoop
Not to the point of adding complexity and cost to an operation.
Posted: Tue Apr 01, 2008 6:08 pm
by Wizard-of-OD
derracuda wrote:but welding and messing with the metalurgy is called de-engineering
No it isnt...
Looking Good though!Carry on
Posted: Tue Apr 01, 2008 6:35 pm
by HighDesertAudi
Nice work!
Want to set me up a package deal with the hubs and the set of the 7.5" twists???
Posted: Tue Apr 01, 2008 6:54 pm
by derracuda
HighDesertAudi wrote:Nice work!
possibly
email me if ya like
Posted: Tue Apr 01, 2008 7:51 pm
by HighDesertAudi
The more I look at it the more ingenious it is. Quick question why didn't you thread the holes and use regular studs?
Would it be possible to do these in other bolt patterns? 5x114.3, 5x112, etc
Posted: Tue Apr 01, 2008 9:10 pm
by Wizard-of-OD
HighDesertAudi wrote:Would it be possible to do these in other bolt patterns? 5x114.3, 5x112, etc
Possible with the 5x114.3....My hubs from the track car were done that way for the Volks.
Posted: Tue Apr 01, 2008 10:13 pm
by derracuda
HighDesertAudi wrote:The more I look at it the more ingenious it is. Quick question why didn't you thread the holes and use regular studs?
hmmm, why didn't i thread the holes... well, mainly because i planned to use these studs from the beginning... the wheel bolt thing kinda sucks even though it works just fine. these studs have the cone on them and make cross threading nuts very hard, and i like that. plus, with this stud arrangement, it helps with the encapsulating of the whole spacer/hub/rotor/wheel package.
5x112 is already doable, 5x114.3 would be a bit of a squeeze on the 5x112 hubs, but i'm not sure if it would work safely...
