Page 15 of 76
Posted: Sat Jul 22, 2006 5:04 pm
by JShadzi
Test fire??
:woowoo:
Posted: Sat Jul 22, 2006 5:43 pm
by Toxcheap
JShadzi wrote:Test fire??
:woowoo:
Almost but Marc reflared the fuel line and it stopped dripping fuel
Posted: Sat Jul 22, 2006 5:48 pm
by Marc
Toxcheap wrote:JShadzi wrote:Test fire??
:woowoo:
Posted: Sat Jul 22, 2006 5:50 pm
by HT Motorsport
Awesome, best of luck Mark, dont forget that video of the first time you run that motor
Posted: Sat Jul 22, 2006 6:40 pm
by Marc
newt wrote:timmmy wrote:dont forget that video of the first time you run that motor
Or the oil to/from the turbos!
lol, my first test run on my 20vt 4kq involved no drain line on the turbo so I got an exciting flood when I finally got a chance to test run it
I'm actually in Manchester right now, wish I had been able to swing by a little earlier and check things out first hand, making some very familiar and good progress 8)
ah man, why didn't let me know? I woulda stuck around at the shop had I known that :(
Posted: Sun Jul 23, 2006 5:02 am
by WAUG0806
Lookin good marc, more fun than a box of kittens!
Looks like you finessed the passenger side frame rail a little bit?
Posted: Mon Jul 24, 2006 3:11 am
by yodasfro
So your feeding kittens to those turbos? :? :-D
Posted: Mon Jul 24, 2006 3:13 am
by Marc
WAUG0806 wrote:Lookin good marc, more fun than a box of kittens!
lol, yes.. finessed.. thats it .. :-D
Posted: Mon Jul 24, 2006 3:14 am
by Marc
yodasfro wrote:So your feeding kittens to those turbos? :? :-D
+50hp shot of kitten, yes
Posted: Mon Jul 24, 2006 6:03 am
by 3bAudios
Looking good marc!!! good luck with the test fire
Posted: Mon Jul 24, 2006 6:45 am
Can't wait to see, I mean hear it done. :-D
Posted: Fri Jul 28, 2006 5:37 pm
by Marc
A little more work today. Still no fire but it'll be soon. I could actually start it tomorrow I think
Heat shielding installed, turbo tightened up to manifold, passenger side manifold finish welded:
drivers side
intake pipe adapter installed and tack welded. The ebay aluminum pipe is pretty crappy and hard to weld even after grinding off the polished surface. To prevent warpage on the intake adapter I may JB weld that piece, not sure yet.
Drivers side oil drain
passenger side oil drain and common oil supply location
More tomorrow
Posted: Fri Jul 28, 2006 6:50 pm
by Toxcheap
Impressive!! I can't believe you got that much done with all the talking I was doing LOL!
Hey thanks too! :wink:
Posted: Fri Jul 28, 2006 7:35 pm
by Ronald G Wainwright+
Marc, on the pic of the driver side drain. How far away from that bracket is the Red part of the fitting were it goes into the SS line?? Looks real close from this angle.
Posted: Fri Jul 28, 2006 7:51 pm
by GTIVR62801
If I get to see this at Watkins Glen I'm going to want a ride. 8)
Posted: Sat Jul 29, 2006 1:02 am
by WAUG0806
Git 'er done :woowoo: :bump:
Motorgeek hacked
Posted: Sat Jul 29, 2006 4:41 am
by HT Motorsport
Hey Mark,
Thought I would let you know that it looks like Motorgeek has been hacked. you may know already but this was the only way I could think on to let you know.
Ty going to the forum home
H
Re: Motorgeek hacked
Posted: Sat Jul 29, 2006 5:20 am
by Marc
timmmy wrote:Hey Mark,
H
grumble.
yeah, looks like the same deal that happened before that I corrected (but never really 'fixed'). Somehow they are able to edit the description tags under the forum to put there own crap in there.
Nate, I dont have time to fix it right now, you on that?
Posted: Sat Jul 29, 2006 5:22 am
by Marc
Ronald G Wainwright+ wrote:[/quote]
Marc, on the pic of the driver side drain. How far away from that bracket is the Red part of the fitting were it goes into the SS line?? Looks real close from this angle.[/quote]
just the angle, plenty of clearance
The area I'm most concerned about is the clearance between the wastegate rod and the framerail on the passenger side.
Posted: Sat Jul 29, 2006 5:32 am
by HT Motorsport
a4kquattro wrote:timmmy wrote:Hey Mark,
H
grumble.
ass bandits!!!!!
Posted: Sat Jul 29, 2006 2:20 pm
Looks great Marc!
Posted: Sat Jul 29, 2006 3:53 pm
by Marc
newt wrote:Apparantly she's up and running. good on ya mate!! :-D
why yes, yes it is :-D
:-D
:-D
^^^^^^^ Thats me, pretty much from the moment I got it running on, still grinning
Myke took a vid, the injector scalar is way off so it doesn't rev very cleanly but I didn't want to mess with it since I didn't have any o2 feedback of any kind hooked up. It took a little bit to get it running because the index timing vs the v80 map I used were quite a bit off, at least 7 teeth or so. Once I hooked up a timing light with Myke's help we got the timing set dead nuts on, then from there the thing pretty much fired right up after adjusting the injector scalar a bit.
:woowoo:
Film at 11 (or whenever myke gets a chance to upload it anyway)
Posted: Sat Jul 29, 2006 5:45 pm
by WAUG0806
I can wait 16 minutes... good go! Great excuse for missing OSQ again!
Posted: Sun Jul 30, 2006 5:53 am
by Toxcheap
Ready..film at 11....am
Marc's coupe first start
Posted: Sun Jul 30, 2006 6:06 am
by AudiSport4000
Oh that is awesome! I like at the end, "cut, cut it off".
I bet you are stoked!
