Thanks guys, no videos yet, unfortunately I'm still mostly taking it easy on her for a gentle break in. Once I get a bit more mileage I'll be sure to post a couple videos!
As for the mean time I just finished up a mini-project I was really excited to accomplish on this car. Something that, to me, puts this project on a whole different level: functional air conditioning. It's all fine and dandy to have a fast car, but I want more than just a stripped out race car. Since this is my daily driver, I want to make sure I'm comfortable driving it long distances in any weather.
The AC presented a challenge for a couple reasons. For one thing, the turbo oil drain goes exactly where the compressor is supposed to go. Secondly, the receiver drier lives right about where the turbo is supposed to go, and lastly the AC line from the evaporator to the drier goes right where the turbo now lives.
So I looked at an S2 clone we have at work.
As you can see the turbo drain goes into the oil pan extension. Not too hard to replicate.
drilled and tapped some holes for studs.
Some red lock tite and I'm in business.
And voila, turbo drain relocated. And a bonus oil drain block off plate.
There was a fair bit of modification needed to mount the compressor, mostly shaving off some material to fit around my oil feed line flange, as well as modifying the lower bracket, which bolts up to where the turbo drain line used to go. I was lucky enough to get a used set of lines from work that we fabricated for a previous S2 clone project.
Here's a pic of those lines.
I relocated the ac drier to the inner fender area and mounted it on a small bracket.
As you can see, the new AC line is routed through the wheel well to avoid the turbo.
I went ahead and added a bit of heat shielding while I was in there for good measure.
Here's a pic of the compressor installed and the lines run. The receiver drier used to go right where the turbo to intercooler hose now lives.
After I evacuated and charged the system, ice cold AC!!
The car has AC, cruise control, a decent radio, and is really quiet when you're driving normally, plus a 20vt. All the things I want in a daily driver.
