Page 6 of 31
Re: 1990 CQ-finally happening! Retirement gift to my self!
Posted: Mon Aug 06, 2012 6:38 am
by scubadave
Clunk is likely trans, rear diff mounts. I would just save up for the solid 034 ones. Double check the rubber around the center bearing on the driveline isn't wasted. If you need a used trans/ diff mount or two I can round up what I have lying around? Although I am sure you saved a bunch of interchangeable parts like that.
Posted: Mon Aug 06, 2012 6:53 am
by Kuma
I sold everything... Like a dumbie
Posted: Mon Aug 06, 2012 6:57 am
Im pretty sure i have a few good trans mount hanging around too. Let me know, and I will see what i can find in my parts mess.
Posted: Mon Aug 06, 2012 7:02 am
by Kuma
That would be awesome guys. I do also need to know how many subframe bushings there are which ones are which and where to get them.
Posted: Mon Aug 06, 2012 7:05 am
by Kuma
Also third gear sometimes makes a grinding noise when I put it into gear.
What RPM is a good shift point? With the exhaust that's on the car it's kinda Blatty.
by Kuma
Think my 200 flow master will fit my car?
Posted: Mon Aug 06, 2012 7:11 am
by scubadave
Well pm me your address and ill send off what I have to you. I have no need for them and they aren't worth but pennies, so we'll call it a welcome to your new coupe baby/audi shower present. just get the aluminum ones from 034 for the sub frame bushings. syncro is bad on the trans, afraid there is nothing you can do short of replacing the trans about that. Flowmasters on na coupes are loud. I pulled mine off happily after too long. I have magnaflow on mine now but the turbo helps quiet it down too. You need anything else I can part with for a good cause?
Posted: Mon Aug 06, 2012 7:14 am
by Kuma
Ummm, I might need better tail lights, mine have clumps of mold or something inside...
My passenger window is SLOW.
Shift boot that's not cracked or crunchy?
My speedo doesn't always work? It bounces and then drops and then will pop back to life sometimes... Dunno if it's a speedo sensor or the cluster itself.
Any other cheap tips will be appreciated!!!
I'll take more photos today!!!
Posted: Mon Aug 06, 2012 7:16 am
X2 on the 034 subframe mounts. As for the syncro, you can still get replacement parts from Scott. When I was looking to parts he told me $75 each for the syncros.
Posted: Mon Aug 06, 2012 7:17 am
by Kuma
How te hell do you turn off the damned rear wiper!!!!!?????
by Kuma
Mr. Scott Dewitt? That's too easy.
Posted: Mon Aug 06, 2012 7:18 am
I totally missed this, congrats on getting the CQ Kuma!
Posted: Mon Aug 06, 2012 7:24 am
by scubadave
Push the wiper stalk forward and it should turn it off. Hold it forward and it blows its load all over the rear lol.
Posted: Mon Aug 06, 2012 7:52 am
Kuma85 wrote:Mr. Scott Dewitt? That's too easy.
No Scott Mandu (scottmandu). He has done quite a few high end transmissions for guys on the here on the forum. PM him and let him know what you are after.
Posted: Mon Aug 06, 2012 7:53 am
by Kuma
Yes Scott Dewitt. He owns advanced automations in corpus Christi. Thanks guys!
Posted: Mon Aug 06, 2012 7:54 am
by Kuma
scubadave wrote:Push the wiper stalk forward and it should turn it off. Hold it forward and it blows its load all over the rear lol.
Okay. Splooge, lol.
Posted: Mon Aug 06, 2012 8:30 am
by SteveJ In Texas
Kuma85 wrote:What RPM is a good shift point? With the exhaust that's on the car it's kinda Blatty.
Stephen, the guy in San Antonio who owned it before me straight-piped it back and eliminated the Cat and the forward resonator, so that's why it is 'blatty' (BTW thats the perfect word to describe how it sounds). I put a universal cat converter and a new O2 sensor on it to pass the Houston emissions inspection, but never got around to putting in a replacement resonator.
As far as the third gear grind, if I drove it without winding it out (which was almost always) it didnt make the grind for me...but then again that tranny has 200K plus miles on it so the syncros have seen their fair share of work.
Have fun!
Posted: Mon Aug 06, 2012 10:35 am
Stephen, if you dont want your trans to end up like mine, you might want to change the syncros soon.
Posted: Mon Aug 06, 2012 2:49 pm
by Kuma
Working on it. Anyone interested in an S2 sunroof panel?
Posted: Mon Aug 06, 2012 6:30 pm
by ur20v
What's the difference between a CQ sunroof panel and an S2 sunroof panel?
I have the trans out of my CQ available... only 104k miles :)
Posted: Mon Aug 06, 2012 6:56 pm
by scubadave
Kuma, if its glass, I may be interested for sure. Leme know.
Posted: Mon Aug 06, 2012 7:11 pm
by Kuma
I'll probably get that trans sooner or later.
I should have specified the panel. It's the control panel for the sunroof.
Its similar but it has a dial to control the sunroof instead of a button.
Text me with your name or mg name and I'll send a picture!
6783570676
Posted: Mon Aug 06, 2012 7:13 pm
by Kuma
I just did the B4 good swap and headlights too. What a pain in the ass.
Good thing I had good friends to help me out!!!
Didn't get around to doing anything else today though...
Pics tomorrow!!!
Posted: Mon Aug 06, 2012 9:35 pm
by pilihp2
Double clutch. Try it.
Also try swapping the tranny fluid to some better higher end fluid. or just fresh fluid for that matter. I put redline fluid and some of their fluid additive(cant remember the name of it?) to a tranny that ground a bit and that helped it to stop.
Posted: Mon Aug 06, 2012 9:57 pm
by Kuma
What's Double clutch?
