PO was an audi enthusiast and purchased from the original owner in California. The car was given to his brother, a car guy didn't know much about german cars. He tried to sell it, someone took it on a test drive and was gone for two hours+ and came back and the car wouldn't run. He did a tune up done on it and spent about $800 to get it to run. Let it sit since last sept. and now it will start, but it only runs until it warms up then appears to starve for fuel or completely die.
Some details on the car:
1986 Audi 40000 Commemorative Edition with the red leather.
All service records since new, clean carfax.
164,335 miles. Odometer still works, all windows work, sunroof works, Etc.
Extremely clean survivor, inside and out - clear peeling on hood though.
Edit: 1/28/17 Current build details
Engine:
AAN (stock internals)
440CC Injectors
034 Fuel rail
Aeromotive FP Regulator
stock 3B intake
URQ intercooler
RS2 Exhaust manifold
3" Stainless TIG exhaust, Magnaflow muffler
Factory AAN Harness
Bosch Wideband 02
VEMS Plug and play ECU
Upgraded oil cooler, custom lines
Drivetrain:
RS2 replica mounts (unknown brand)
01E "Wide first" 5-Speed
URS interior parts to retain reverse lockout
034 Short shift kit
Ground Control adjustable coilovers
Koni Struts
16 ATS Type-10 wheels
Maintenance:
Relocated battery to trunk 9/2016
New battery 9/2016
Fuel Filter 9/2016
New Tires 9/2016
New front Ball joints 12/2016
New rear Ball joints 12/2016
New front tie rod ends 12/2016
New front wheel bearings 1/2017
New alternator brushes 1/2017
Oil pan gasket 1/2017
Brake fluid flush 1/2017
Trans Mounts replaced 1/2017
Engine bay
