A few weeks ago, I took a day trip up to northern Ohio to visit the fine folks at German Auto Pro's (who, by the way, have some sweet-ass cars!). What started as a small parts haul for the 200 very quickly turned into hours spent playing with their 200's and lusting over their factory 5-speed V8. We went out to eat, and by the time we got back, I had somehow been convinced to haul back ~500lbs of parts I didn't know I needed. Among those being an 016 from 200 20v!
And so it begins...
If you, uh, notice the big shiny part, a huge shoutout to Ben for helping me track down a brand new unobtanium Fidanza flywheel! Seriously, that takes a lot of headache out of just having this trans sitting out under the porch.
I've been looking into everything I need to collect to complete the swap. Luckily, others have forged the path already, but I'm definitely going to need access to a parts car. I know there's a shop parting two 20v's about an hour from me, and I'm hoping they can make me a package deal, because this going to be $$$ otherwise.
Stand-alone parts needed
016 Transmission w/ 4.11 Final Drive
10-bolt Flywheel
200 Pressure Plate
200 Clutch Disc
016 Pilot Bearing
016 Throwout bearing
x10 Longer flywheel/crank bolts
HPR Transmission mounts
Parts Car
200 Transmission Tunnel
200 20v front axles
T44 Clutch/brake pedal asy
T44 Clutch master
T44 Clutch slave
016 Shift linkage
Transmission arms
200 20v Driveshaft (rear)
I've got parts in green. Yellow, I'll probably buy new, though I'd consider a good used one. For the clutch, I'm just going to order a stock 3B unit to keep the cost down. The rest I should be able to track down from a 200.
The only thing I still need to figure out is the transmission mounting arms. I know they are different on the V8, but from what I read, I should be to space out the 200 one ~1" to make them work. Unfortunately, I wasn't given those with the transmission, so I'll have to either find those, or genuine V8 5-speed parts.
That's it for now! Hopefully this won't been too drawn out of a process. If I can arrange everything, I'd like to try and get this done during fall break.
