I got a chance to go to the farm and work on the Rennwgn again this past weekend. I had a few parts come in from Germany.
NOS CAC Ruhekissen in Platinum
I have 8 total... not sure whether I actually want all 8 or not, so if anyone wants some let me know
Some of the last remaining (2 sets) of Euro reflectors
The first order of mechanical business was the Cayenne though. I won't go into detail, but it needed a headlight bulb (BI-XENONS NICK!!!!) and a small bird had to be extracted from inside the intercooler bumper opening
Luckily the headlight pops out with the turn of a single hex head bolt. Pretty ingenious, but of course VAG/Porsche couldn't get it completely right, so the hex key is a 9 mm. Who the hell uses a 9 mm?!?!?
Not that easy to find in a regular set of hex keys let alone the bits to fit a 3/8 ratchet. ANYWAY...
Then I spent a pretty good deal of time trying to figure out how best to route the boost gauge and the ridiculous amount of wiring that goes to it to the vent area. I didn't get any pictures, but I did it very cleanly in a way which makes doesn't affect any aspect of vent operation. I just had to trim a thing or two. I can get pictures sometime if you guys want.
Here it sits while waiting for a vent with cut slats.
Then I tested the gauge and found the car to make between 18 and 20 psi peak, tapering off to 15 psi later on. What is interesting is that it will hit "boost cut" with the cutout open, but not with it closed. This often happens even when the boost is tapered off. Maybe that's a lean limit or something rather than "boost cut" as I normally think of it.
Either way, VEMS will solve that problem
Then I FINALLY washed it for the first time. I haven't had the spare time since I drove it home because I've been busy doing more important things like installing boost gauges and speakers
Unfortunately, I found a leak at the rear hatch after the washing.
Not exactly sure where it's coming from, but you can see the a drip around the seal. I don't know, but I'll have to solve this issue ASAP!
