AngryTaco wrote:AudiSport4000 wrote:oh deer
Im confused. What do chicken of the forest have to do with turbos?
*cracks whip* GET BUSY BOI!!!
audifreakjim wrote:So you are going to make your 20v head into a 20v head by re-shaping the CC? Why not just drop on a 3b head an be done with it? You will have the same low CR ratio in the end.
It is painful to sit back and watch this.
pilihp2 wrote:Stick to the 20v, but be smart about it.
40v4kq wrote:I have a 3b engine with no intake manifold a few other things (still has wire harness and ecu) sitting in the garage, and I also have a 7a head minus camshafts right next to it. Also, I have a 200 20vt that runs and drives that im going to part one of these days. Has fresh valve job with AAN HG and ARP headstuds and exhaust studs. Just an FYI
10 miles into the cruise, I get on it hard going up hill and then I lose all power with a HUGE smokescreen suddenly behind the car. Check the engine....fucking igloo popped off the CIS dizzy. The cylinder rings were already smoking, so I pretty much expediated the death of the current ones.
dana wrote:aren't you also running mc2 pistons with mc1 ignition?
I did this once with EFI and chipped mc1 ecu, it was nocky nocky nock.
