-2014 Lexus IS350 - SOLD
-2015 Yamaha FZ-07 - SOLD
-2005 Honda CRF230F - SOLD
It needs (bigger) turbo! The Avant that is.
- amd is the best
Ehhhhhh, maybe someday, lol. Just a chip would be nice for now.loxxrider wrote:It needs (bigger) turbo! The Avant that is.
- themagellan
Could be a blessing in disguise, this will give you the time to give it a proper break in triple check everything. There is a lot of coin in this build always good to do things with enough time.
Hope you at least cranked the avant's waste gate down
- amd is the best
I agree. I hate to rush things and it was just too close. Avant is at stock boost. Cranking the WG spring would only make it hit overboost right?themagellan wrote:Could be a blessing in disguise, this will give you the time to give it a proper break in triple check everything. There is a lot of coin in this build always good to do things with enough time.
Sweet, one more fast car knocked off the list, looking good fit the 4k. LOL.
Do it right, you know how/why.
You can crank it down until you hit overboost and then back it off just a bit. It would net you a few psi and at least make the trip down a little more fun!amd is the best wrote:I agree. I hate to rush things and it was just too close. Avant is at stock boost. Cranking the WG spring would only make it hit overboost right?themagellan wrote:Could be a blessing in disguise, this will give you the time to give it a proper break in triple check everything. There is a lot of coin in this build always good to do things with enough time.
Whoa, those are sweet.
glibobbo21
Dutchbroracer
Not a fan of the carbon fiber look. Though I must ask...Are those real or wrapped?
CF touches aren't rice if they're a feather in the cap on a completed build... if all you have is a 4" exhaust tip and some neon lights and a CF hood or something... then yeah, rice. Otherwise, CF because racecar.
Yeah, but putting it in unnecessary places also makes it ricey in my opinion. CF door trim....really?PRY4SNO wrote:CF touches aren't rice if they're a feather in the cap on a completed build... if all you have is a 4" exhaust tip and some neon lights and a CF hood or something... then yeah, rice. Otherwise, CF because racecar.
It's nice for aesthetic purposes in interiors & engine bays, IF NOT OVERDONE. And obviously it's great for weight savings on panels/etc.
- amd is the best
- themagellan
Ugh so jealous, everything looks like it was made to fit. lol….
It's a RS2 exhaust manifold ?
Audi 200 T44 3B 89" _ 90 B3 NG 88" _ 200 T44 1B 89" _ 90 B3 7A 90"
http://www.explosm.net/comics/random/
Looks the business.
Any reason you opted for OEM CP's instead of LS2? No worries about heat?
One other thing (I can't help myself)... looks like it's time for a CF TB cover
- amd is the best
Wagner Engineering Sport Quattro Evo.Clem86 wrote:![]()
Thanks! I ran LS2 coils for years and never had a problem until some strage misfire issues arose and couldn't be traced. After replacing every component, still no fix. Also tested my coils and harness on another car and they worked flawlessly. As a last ditch effort I tried the R8 coils and they worked perfectly. They also look nicer and cost under $20 to replace if they fail (which hasn't happened yet).PRY4SNO wrote:Looks the business.
The CF timing cover would be sweet however I don't believe they make a 3B one that clears an aftermarket pulley. And there's no way I'm going to try cutting one up.
Pretty sure there's one for the adjustable on the 3b... I could be wrong.
- amd is the best
Last edited by amd is the best on Sat May 24, 2014 9:01 am, edited 2 times in total.
sounds amazing.
Yesssssssssssssss
Your passenger was pretty excited about 5psi or whatever that was
No launch control break in procedure?
- themagellan
I honestly have no words, I am just proud to see this.
